| Good evening,
I drained hub oil today on my 4830 and the right rear hub was way overfull and pressurized. When I pulled the top fill plug to relieve pressure it spewed oil out for a while. Sounds like it could be a seal or oring on the internal park brake leaking, or less likely a wheel motor seal putting oil in the hub. Anyone had this problem? If so, did you fix it yourself? It's a 2010 model with 4600 hours.
Thanks! | |
