Southeastern Tipton County, Indiana | WLR - 5/8/2021 15:52 We are having trouble with the cvt transmission overheating when planting. Changed filters, blew out cooler. Still gets hot. Does anyone know what this cooler bypass valve does in pic? I assume maybe that it doesn’t send oil to the cooler when cold? Could this cause overheating? Where is it located? Any other suggestions on what to look for?
The cooler bypass does what it says, it prevents cold oil from being forced through the cooler. Yes, it can cause the oil to overheat, just make sure the oil is actually getting hot as the sensors also can fail and show hot oil. |
