| All 4 scvs settle when hooked to the lift on a disk. Multiple disks, so I know it is the tractor. I put new seals in for the scv barrels, the internal ones when you remove the barrels, as recommended by my dealer. It appeared to hold. But it settles again when warm. Must be the internal seals on the scv spools? Only happened after running a highly hydraulic planter for the first time and the oil was hot. Not hot enough to trigger the warning light. Think some 20 year old seals finally gave out with the heat? | |
