Posted 5/9/2021 05:42 (#8994999 - in reply to #8993653) Subject: RE: Nav 2 pinout
Not when steering is disengaged... If you had a Nav3, it has a “when engaged” output. The FM1000 does also have a Remote Output function that you can set to “When Engaged” and it will output 5v from the rear of the display, which can be stepped up using a common 5-6v relay.
