Southeast MN | On my 2013, I put a put of foam rubber roughly 1/8" thick x 3/4" square between the handle and the "outer" edge of the slot in moves in. A bit of double sided tape holds the foam rubber to the handle. Going on 2 years with it in there and forgot all about it until you posted this.
Before I did this, the handle had about 1/16" of free travel and was just loose enough on rough ground that the cvt acted like I was moving the handle. | |
