Posted 5/7/2021 11:00 (#8992027 - in reply to #8991995) Subject: RE: Ag Leader Insight in a Case 4410… pump control settings.
You could put the system into manual valve control on the run screen and use the up arrow to increase the pumps duty cycle. You should be able to do this while sitting still and the pressure should increase. You can then flip back over to your target rate and start spraying.
