Posted 5/6/2021 11:19 (#8990415 - in reply to #8990395) Subject: RE: 3600 Kinzie vacuum planter
NE Indiana
The flat face one needs to go straight into the rearend housing. Deere makes a kit for that. Guessing the smaller hose with normal tip is the pressure line and the bigger hose is the return. Then you will also need to get the hydraulic lever lock for inside the tractor, it will lock your remote in constant.
