| Correct me if im wrong, but cant you put the PMW standby to 0 and it will keep the pump at the last know duty cycle? If pump was running at 50% when the master switch was shut off it will stay at the duty cycle until the sections kick back on. as long as your speeds going into the headland is close to the speed you are traveling while leaving the headlands the rate should lock on very quickly because the pump doesn't have to adjust very much. I always recommend taking a picture of these settings before you adjust them and only play with one at a time. | |
