Posted 5/13/2021 19:57 (#9003825 - in reply to #9003183) Subject: RE: Same issue with JD r.c.
W.C. MN
Thanks for the reply.
I don't currently have section control.
I have figured out that the rate/ min. Option seems to get the applied pressure up the quickest after making head land turns.
However, lately it seems when rate is set to gal./
Min, then my manual button doesn't turn on flow in corners. Ugh. Back to a too-high-a predefined rate then turn down after up to speed
