Search Forums | Classifieds (192) | Skins | Language
Jd 8770 4wd auto trac HELP
Michfarmer52
Posted 5/1/2021 20:16 (#8982317 - in reply to #8981718)
Subject: RE: Jd 8770 4wd auto trac HELP
Mid-Michigan
I will try those settings tomorrow to see if helps. I tried changing the fore/aft of the receiver from the front axle, but I can change it in the "auto trac" section on the brown box, but when I click on starfire 3000, it still says old measurement. Maybe this is causing an issue,not not? Thanks again .
