Posted 4/28/2021 09:12 (#8976760 - in reply to #8976693) Subject: RE: InCommand Coverage Logging and Clutch Problem
Hillsboro, AL
tedbear - 4/28/2021 08:38 His screenshot legend seems to be referring to an application rate. This is how the screen would look with a spray setup with section 1 ON and OFF but with no spray detected by the flow meter.
That is correct. And the InCommand will only log when the bar is green and there is flow. But he is saying flow stops when he turns the switch "ON". Think of the switch as turning the "SEED" on and off, not the clutch on and off. When the switch is on, the seed should be on. But he is saying the clutch is on stopping the seed when the switch is on. That is backwards.
