Posted 4/25/2021 23:42 (#8973302 - in reply to #8973146) Subject: RE: Can you connect 2 pro 700 monitors together?
roaming
bec09 - 4/25/2021 20:46
Wondering if you can connect 2 Pro 700 monitors together to be able to watch them simultaneously. Would like to watch guidance on one and liquid control on the other. Using a Case IH 2150 planter. Has anyone tried this? Thanks.
You can run two 700s at the same time. They don't actually talk to each other, but you can do different things on each one.
