Search Forums | Classifieds (6) | Skins | Language
Raven 440 Cal Issue
tedbear
Posted 4/25/2021 21:48 (#8973152 - in reply to #8972391)
Subject: RE: Raven 440 Cal Issue
You need to finish entering all the numbers that the 440 needs such as all boom widths, speed cal, meter cal etc. Pretty much every button on the top row needs to have a number entered. Boom widths 1,2 & 3 are each section width in inches. If you are not using a boom enter "0" for its width. The speed cal will depend on the device being used, try 650. The meter cal is the value stamped on the flow meter, try 740. The valve cal tells the system how to control the control valve, try 2123.
If it still flashes cal, you've missed entering one of the values.
Edited by tedbear 4/26/2021 05:51
