central iowa | hobby95 - 4/23/2021 20:26
I have an Integra controlling my starter fertilizer and a sidekick pump on my planter, planter itself is run with a 20/20. Everything is getting RTK GPS from the Nav in my 380 magnum. Speed in the integra is reading about 20% slower than the tractor and the 20/20 which are within a tenth of each other. The coverage map is also goofy it looks like the planter is dogtracking and swath spacing is also off, skips one way and overlaps the other. Track spacing on the 20/20 is right on. So far i have unhooked the 20/20, tried different display cable, tried monitor in a different tractor (speed was correct in there), tried differnt display in this tractor same thing, speed is off.
Tractor does have a steering fault that wont let autosteer work, code mentioned steering sensor. Seems to me like two unrelated issues but could they be related?
Edit -- Integra has current update. i think its 7.2 or 7.6 or something like that.
What data strings do you have turned on to the integra and what is the baud rate and hertz setting |
