Search Forums | Classifieds (206) | Skins | Language
Implement on FMX is going through the field at an angle.
NFarm
Posted 4/28/2021 22:03 (#8977836 - in reply to #8968968)
Subject: RE: Implement on FMX is going through the field at an angle.
SC ND
Not sure if you got this figured out, but I’d guess if you go under the geometry tab on your implement setup, you will find your error. Hitch to ground contact point. The other measurement is rear axle to application point.
