| We are running a new to us 2016 DB60 with new 580 with a pro 1200 monitor with a new style receiver. We want to run guidance with the tractor and all planter functions through a 2630 monitor, but we can’t get the 2630 to read speed. In the past we had the 2630 pulling speed from a GPS “hockey puck” on top of the cab and connect into the Deere harness via the 4 pin radar cable, with no problems. This is not working with the new DB. Deere has been out four times to try different things including planter software update and and making a new harness to pull speed from the receiver. No luck. Case has been out as well and has not been able to tie into the Deere harness by pulling speed from the planter.
Is anyone currently running a setup like this? Running a 2021 AFS connect tractor and running a 2630 and successfully pulling speed from the tractor? Looking for any ideas or suggestions. TIA. | |
