Posted 4/21/2021 11:45 (#8965094 - in reply to #8965065) Subject: RE: Are Raven Phoenix 200 and MBA-6 compatible?
Butterfield, MN
No. The MBA-6 is designed for a separate receiver, it's just an antenna. The Phoenix 200 is a smart antenna, so it has the receiver built right into it. You'll see the difference by looking at the plug type. The MBA-6 uses a metal coax type plug with a single pin. The Phoenix 200 has a plastic plug with 8 pins, I believe.
