Missouri river bottom south of Sioux City, IA | Hi Don
Using a splitter cable, you can output NMEA sentences while using an external GPS with the EZ-Guide Plus The EZ-Guide Plus has one serial port so the only stipulation is the device needing the NMEA output would have to use the same baud rate as the external GPS.
I setup several RTK Ag332 with EZ-Steer on combines running Ag Leader Pfadvantages. The Ag Leader monitors can’t take 38400 baud rate so we used Ag106 for them.
Tom N.
