Posted 4/21/2021 07:11 (#8964559 - in reply to #8963411) Subject: RE: Can't get oil to go through autopilot valve.
Eastern SD
What if you crack one of the lines on the work ports? Is the valve connected to a cylinder that can move?
If the cylinder is blocked, you'll build pressure but not have return flow.
