WC Indiana | It sucks when you can't plant because of a computer.
I have a Pro 700 that keeps rebooting. First the corner panel displays " No color Monitor" Then the Pro 700 says the configuration has changed and it must reboot. It either stays in the infinite loop or it beeps about 6 or 7 times and freezes on the loadup screen. It's in a magnum 235 with Ag Leader Steering and the Ag leader gives the Pro 700 GPS through the RS-232 Port B serial port. I says this because the local dealer has been out every day and keeps blaming Ag leader but I don't think that has anything to do with it. They keeps saying the GPS has to say "not installed" but the only way I know to do it is say you have 372 and set the port for RS 232 port B to get the GPS from the Ag Leader.
Hope someone can give me a tip about where to look or have them look?? Thanks.
Added Later. I have used Ag Leader for 10 years on about 7 different tractors and set them up exactly like I described. I have an identical tractor with identical setup planting beans with no problems.
Edited by Barker 4/8/2021 01:11
