This is what I ordered from Surplus center a few days ago:
9-7876-F valve 9-4895-closed center plug 9-6706-rd - connection kit (need 3) Need to know length of cables 9-6704 single joystick 9-6704j dual axis joystick
This does not include the cables. I wasn’t sure where I would mount everything so I’m going to figure that out before deciding on cable length.
You should note that this is not the kind of joystick where you hold a button on the joystick to access the 3rd function. Instead it had a separate lever for the 3rd function which I wanted for my application.
So far I’m north of $900 without hoses, power beyond block and cables.
I’ll be installing on a JD 4430. It won’t fit as good as factory but factory joysticks now cost a fortune and I just need it to work. |
