SW Ontario | We are VR but here’s an ave:
100lb AMS (21-0-0-24)
30lb potash (0-0-60)
10lb Mn
150lb MAP (11-52-0)
50lb K-mag (0-0-22-22-11)
Actual nutrients applied:
38-80-29-36-11
This is rough math might be off a pound or two on actual applied. We variable rate the MAP and Kmag in rear bin of our air cart so we do apply over 400lbs of product in the ground that calls for it. Never seen an issue in thousands of acres of corn. This is applied 2x2 with John Deere single disc openers. Very sandy soils in some cases. | |
