SouthCentral WI | I don't know IH, I would check a couple of things. (I know it isn't easy) The first is that the inner steel ring of the cover is fitting up into the recess area. Check the recess for burrs or wear that would stop the fit. You could measure the depth of the recess to see if it is allowing a full seat.
The second is the fastening stem (bolt). Make sure you don't have an issue where the cover is not being allowed to seal because the stem is keeping it from seating. How does the stem get sealed to the housing? Gasket or oring? If gasket, does it need to be thicker?
The fact that you can move the cover slightly, makes me think something is going on other than just a thicker oring seal.
Just a couple of thoughts.
Towman
Edited by towman2000 3/8/2021 18:44
