Search Forums | Classifieds (138) | Skins | Language
Utility tractor: how many hours is too many?
JD 9400
Posted 3/3/2021 07:58 (#8869801 - in reply to #8869746)
Subject: RE: Utility tractor: how many hours is too many?
Southern Pa.
bsfarms - 3/3/2021 08:39
7210 is a better machine than a 6410 here. The 6410 has a 4cyl and the 7210 has a big 6 cyl that is used in the larger tractors. It also rides better due to longer frame and slightly larger front wheels (2wd). We had the 7210 on the mixer and had it rebuilt for the 1st time at 24,500 hours. We went to a bigger mixer and dont use it much anymore. The 7210 and 6410 were bought 1 year apart around 2000 with under 200 hours each. The 7210 has 26,000 hours and the 6410 has under 10,000. Both should go well over 10,000 hours before issues. I just like the 7210 more.
The 7210 pulled a 700 cu ft mixer, so was overloaded for most of the hours.
A 6410 and 7210 have the exact same engine design, but the 7210 has 2 more cylinders, making it 50% larger. 6410 has a 4.5L, 7210 has a 6.8L. Exact same engine family.
The 6 cylinders are really smooth. Both are good engines, same internal parts.
Had a neighbor with a 6400 (same basic 4.5L) on a mixer wagon. Retired it at 27,000 hours with no huge repairs. Injector pump, injectors, and PTO clutch were rebuilt, IIRC.
Edited by JD 9400 3/3/2021 08:09
