Posted 3/2/2021 22:13 (#8869264 - in reply to #8869159) Subject: RE: JD 4320 seat suspension?
Seat retractor. When you lift seat position handle (14) it lifts position latch (5) out of the selected hole in (26) and the retractor coil spring pulls the seat assembly up to the top of the ramp using the cable. The cable end goes to a wire hook welded under the ramp (26). It will hold the entire seat assembly up so you can stand up on an open station tractor. Hope this helps.
