| I had a little snafu with the hex shaft that drives the transmission pump and I'm pretty sure there is a burr on the end of it. It is also slightly bent. I can't get it pulled through the pump to get it out of the tractor. My question is would it be better to pull the cab to get at the other end of the shaft or split the tractor? Or can I go through the floor in the cab? Any advice would be greatly appreciated! | |
