Posted 3/3/2021 08:51 (#8869947 - in reply to #8869547) Subject: RE: sawzall blade recommendation
E ND
I'd agree with this. Cut the bottom with the circular saw, break the tope loose and get it on the ground. Use a pry bar and pull that middle board off all at once HOPEFULLY taking all the nails with it. It doesn't sound like fun to take the time to cut all the nails then I assume you'll also have to figure out how to remove all the cut-off nails from your boards.
