Working on a older Dodge Truck with a hydraulic clutch. Reservoir was empty of fluid, I filled reservoir with brake fluid but can't get it to pump up. What is the best/easiest way to get it bled? There is a bleed screw on the slave cylinder but not the master cylinder. Master cylinder and slave cylinder are similar to the pictures at this link. TIA
