Near Intersection of I-35 & I-90 Southern Mn. | According to my notes: Pin 1 - 5V power for flow meter or shaft sensor. Pin 8 Ground. Pin 5 signal from flow meter or shaft sensor.
May need a 10K ohm resistor between Pin 1 and Pin 5 to act as a pullup.
I forget if the cal number works with CFR or if you need to come up with your own cal number that converts the speed of the chain into pounds for a given gate height.
Edited by tedbear 3/3/2021 15:23
