Between Omaha and Des Moines, 7 miles South of I80 | Here's the Note, I get when I try a 400 gallon front mount configuration for a JD 8410 tractor:
Notes: Will not fit 2wd tractors & Use of 400 gal tank is not recommended by tractor manufacturer. Minden Machine Shop Inc. assumes no responsibility to damaged tractors
https://patriotequip.com/products/fertilizer-equipment/front-mounted-helicopter-tanks/ |
