Posted 3/2/2021 09:23 (#8867757 - in reply to #8867497) Subject: RE: NhT8 rear hitch
Have you turned your draft sensitivity all the way both ways? Incorrect draft sensitivity will make the hitch rise when you back up. Are there any fault codes active? A draft pin fault will also make it do that
