| As said previously, tie a rope.. or. ..
If it is a female type fitting, example JIC flare, get a male to male JIC adapter, and when you pull the old one out, pull the new one in its place. this will only work if you know your length needed, or have a portable crimper.
If you need to push one, and scared of steel, a 1/2" PVC stick of plumbing pipe will work and is flexible, and can easily have couplings glued on for extra length. | |
