central iowa | Doing my thing - 2/28/2021 20:47
Is there a kit available to move a versa monitor from a 9500 combine to a case 7220 tractor for planting. I would like to move it without enduring all the wires Thanks
Yes, the only thing that you even could use from the combine is the cab cable. Most leave them in the combine and buy all the other components for the tractor. You will need to get with some local at leader dealer to get you what you need depending on what you want to control/monitor on the planter.
Best get what you want ordered in a hurry, the aftermarket suppliers are EXTREMELY behind this spring so if you want it best get it ordered. Ag leader seems to be as behind as i have ever seen them based on orders I have put in for me and a couple customers.
