NW IL | There are two serial ports on the paradyme aux cable. Which one do you have connected to serial cable that feeds into back of incommand? Assuming you have it connected to port A, in the paradyme set up menu do you have baud rate set? NMEA message GGA turned on?
The 2 pin connector coming out of aux cable is used to power up external cell modems or radios. For your application i don't think you will use it. | |
