Posted 2/28/2021 19:21 (#8864568 - in reply to #8863834) Subject: RE: Drilled and slotted brake rotors
north central Kansas
I had a Pontiac G6 that a local mechanic told me was a heavy car for the size of rotors it had. I replaced warped rotors with drilled and slotted and it seems to have helped. But as stated before, you have to keep people with big impacts from over-torqueing them. This car says 100 ft-lbs and every time a tire gets put on somewhere else I check and usually find it 150-200.
