WC MN | What's a disk ;-) Not sure what a disk would be used for other than to bring up sod slabs and convince your self covers can't work. Assuming your planter is well maintained, just go plant, then decide when to spray rye out. If you used very minimal tillage seeding rye in the fall your ground will be firm enough to plant in relatively wet conditions in the spring. Here rye is only boot high (at planting and can adjust burndown to how wet ground is. I would think you'd have more spring growth in your area. | |
