Posted 2/28/2021 14:08 (#8863837 - in reply to #8863173) Subject: RE: 1086 cab power relay
If you replace the relay again, make sure the parts store gives you a cab power relay and not a start relay. Only the cab power relays are rated for continuous use even though they look the same. I have seen start solenoids used in place of cab power relays. They over heat and fail in a short amount of time.
