Nebraska | We have been working with Agra-GPS to try and get their CNH-JD Bridge to work with a 2011 Steiger.
Their 2012+ Steiger install manual says "Find the connector labelled C602 behind the panel. Open it and insert the 12-pin DTM connectors of the provided AgraGPS harness. Note: It is sometimes also called the display connector! You also find 2 * 4pin DT connector with an ISO label at about the same spot. Open it and insert the 2 * 4-pin connectors of the AgraGPS harness here."
In the right-rear corner post, I don't see anything. Only thing I have found is an 8-pin connector labeled "Autoguidance/ISO" that is located bottom/right near the fuses. Any idea where these cables could be located if at all? Roof maybe?
Attachments ---------------- CNH Quadtrac12.pdf (1429KB - 147 downloads)
