Quebec, Canada | I've been told that the gen 3 20/20 monitor can run a script on some rows of the planter while running a flat rate on the other rows. I do not know if you can run multiple different scripts, but it sounds like it is easy enough to switch scripts in the field. Label your scripts "FieldName-High/Med/low" and load all three into the monitor. Plant a pass at High, switch to Medium for the next pass and then Low for the third pass. Consider setting 12 rows (or whatever width matches your combine) to a recommended flat rate that can act as a check strip. | |
