Posted 2/15/2021 09:53 (#8833827 - in reply to #8832262) Subject: RE: Centrifugal Hydraulic Pumps
Cen IL
Ace is the best choice. On the Hypro,the hydraulic motor shaft is also the pump shaft and makes for a bigger hassle when you go to rebuild the pump. The Ace has a separate shaft for the hydraulic motor and centrifugal pump. Centrifugal pump rebuild is easier, because of that.
