Cedar Rapids, Iowa | What base do you have?
Did you record the fixed latitude/longitude/altitude of the base prior to moving it from the grain leg? If you have the coordinates, you can just re-enter them in the base.
If you don't have the coordinates, but know how far the lines have shifted, it's possible to do some math and manually adjust the lat/lon on the base to compensate.
Rule #1 for RTK bases is always document the fixed lat/lon/altitude for a permanently mounted base. | |
