39.48, -82.98 | No documentation on this one. Maybe I can search on the exact model. As it is, operation is not particularly intuitive. You have to press the Zero button to print a ticket, for example. But that button press probably triggers a string of data. You might get it by guessing, but a good tech manual would be helpful.
I imagine a moisture tester is very similar. I've done a fair amount of coding in Python, but have not done anything with "front end" data entry. Maybe someone here has experience with Django or some other design tool? | |
