Posted 2/10/2021 21:02 (#8823068 - in reply to #8822897) Subject: RE: Soil water improvements with the long-term use of a winter rye cover crop
WC Mn/Dakotas
Mikenesd - 2/10/2021 20:12
[QUOTorE]GOOSEPILOT - 2/10/2021 16:04
Vrt seeding alone would go a long way towards managing this issue.
Do you think just putting higher populations on the better soils is only way to use up the extra water to raise yields, or do need to adjust fertility as well?
Depends on the crop, some need more some need less population to match the environment. Bigger yields use more and or more efficiently depending on situations. Crop or cover crop? They each need to be address a population balance. I can start off someone with vrt population easier than anything else. But ultimately you need to fine tune the population and incorporate the fertility and if possible manage the water all in unison.
