Near Intersection of I-35 & I-90 Southern Mn. | I agree with the above reply. It seems likely to me that it already has the ability to do what you want. As the other post suggests, the OEM joystick section switches may have been rewired a bit to be inputs to the Ag Leader system. If so, there would likely be a black box or module somewhere in the cab called an Auxiliary Input Module. Essentially the switches and the Auxiliary Input module tell the system which sections you are giving "permission" to be on. The system can then decide to shut off sections based on its own internal map to perform what is known as auto swath.
There would also be another black box called the Liquid Product Control Module. Its purpose is to receive flow information from the flow meter. It controls the spray rate and section valves.
Pictures would be very helpful for us to see what you currently have. |
