Posted 1/25/2021 19:44 (#8781515 - in reply to #8780752) Subject: RE: JD Operation Center Map Changes
Midwest
If you have wireless data transfer in the machine your display is in (MTG w/ JD Link Connect) then you can make the setup file in Op Center and send it from your computer over the air. If you don't have the wireless capabilties on the machine, you can use USB or use wifi on the display.
