| They will change part number depending upon software version as well. Your Dealer should be able to supply the current .pdf version to you. As mentioned previously, make sure you ask them for the Display, Large/Medium Tractor, Precision Farming & Autoduidance, as well as ISOBUS if you are using it. If you’re using it in a combine, seeder or planter etc, they will be able to provide these as well. | |
