| A neighbor and myself have newer style CAN based plows. His harness inside the pump cover was eaten thoroughly by mice. I had the proper sized female Metri Pack connectors to make the fix, however it wiped out my limited stock of terminal ends.
Anyone have any idea what size Metri Pack series that Western uses for their modules? I know on the pump side, there are two different sizes, one for the module and a slightly larger one for the fuses.
The size I need has grommets that have a slightly smaller outside diameter than the ones that Weather Pack uses. The fuse connectors DO use the same grommets as Weather Pack.
Thanks. | |
