WCIA | What tractor and what planter. Some planters have implement switches on them that can make the screen map. Some later Deere tractors can turn on and off mapping by using an scv. If you don't have those options. You'll need to add a lift switch. Ag express sells a couple different models. Should be an implement switch connector on the back of your greenstar harness by the big implement can connector. | |
