Quebec, Canada | Are you looking at the outback that runs the hydraulic steering valve on the tractor, or the one that has a motor on the steering wheel? If you are looking at the motorized steering wheel then have a look at handsfreefarm.com at the wheelman pro. The system is cheaper because it uses your tablet or smartphone instead of having a dedicated monitor. Outback has the advantage that it could run section control on a sprayer (if you decide to go that route in the future) and depending where you live there might be a dealer nearby that could help you out (I think all the Wheelman support is over the phone). | |
