Search Forums | Classifieds (362) | Skins | Language
Need cheap auto swath for sprayer, for now
caseihfarmer
Posted 1/3/2021 15:49 (#8719709 - in reply to #8719684)
Subject: RE: Need cheap auto swath for sprayer, for now
East Central, Nebraska
that is about what insight bring, and they are still a pretty decent monitor even after about 15 to 20 years old. as i stated though keep in mind you need the items i listed to make it work. switchbox and module can likely be found used for about 4-400, liquid product modules are a little harder to find used but i have seen them $4-800 used, and wiring to go to raven controls should be pretty common used but i have never found them when i was looking so new cables to go to raven controls from liquid module will run couple hundred, you will need implement and display harness's and power cables. id say youll pretty easily have $500+ in just cables and wiring.
good thing about agleader though is that the same cables will be used no matter if you have a 15 year old insight or a brand new incommand.
